" /> Chat Widget - Genesys CTI User Forum
Author Topic: Chat Widget  (Read 1677 times)
Offline Mohamed Saber
Chat Widget
« on: February 27, 2017, 03:16:59 PM »
I have deployed Chat widget and all is working well except uploading files, when I upload file from client side, the file transferred to Workspace but i can't see the file in chat, and when i looked at console i found this error ( [b]Cannot read property 'file-name' of undefined[/b] ), and when I made file name, file size, and file id static, i saw the file which i uploaded, but it is not correct because the file data is static, so, I couldn't find where is the error if the widget use the variables before the HTTP request or why these variable doesn't have correct values.
Best Regards,
Re: Chat Widget
« Reply #1 on: November 17, 2017, 07:14:25 PM »
Just to answer something here, UCS is needed for File transfer. Do you have it on your ChatServer app and on GMS?
Re: Chat Widget
« Reply #2 on: November 20, 2017, 08:45:27 AM »
Also check your GMS version as the file transfer is supported since specific version.
