" /> How to remote login GAX Setup mode? - Genesys CTI User Forum
Author Topic: How to remote login GAX Setup mode?  (Read 3471 times)
Offline cmpark
« on: March 02, 2017, 05:30:38 AM »
GAX installed Linux.
Linux configured only core. - NO GUI, NO Browser
How to login 'root' account in remotely?
Offline RobertH
Re: How to remote login GAX Setup mode?
« Reply #1 on: March 02, 2017, 06:36:44 AM »
I didnt found the way around it. But installed x in few minutes from command line and made it switchable on startup. Works nice on cemt os. I can send commands.
Odoslané z D5803 pomocou Tapatalku
« Reply #2 on: March 02, 2017, 10:30:44 AM »
You are not able to connect to that machine remotely (the machine is not on network)?
Offline Dionysis
« Reply #3 on: March 02, 2017, 03:30:35 PM »
You can do it via X window redirection, so set that up (google is your friend), ssh to the machine, then run firefox from the command line (yum install firefox if necessary).
Or, you can do it via the VM console tool if you're running it as a virtual machine.
Offline cmpark
« Reply #4 on: March 06, 2017, 05:47:25 AM »
I know what is x-window.
but customer's O/S not installed x-window because security policy
Offline Dionysis
« Reply #5 on: March 08, 2017, 12:03:43 AM »
You'll need to work with your customer's Linux / Sys Admin team, the server needs to have Firefox installed, and window redirection configured for your ssh user.
Offline keisim
« Reply #6 on: April 05, 2020, 07:02:59 PM »
Use PuTTY to setup the SSH tunnel from the GUI host to the GAX host.
Source port:  8080
Destination:  localhost:8080
Then just navigate to http://localhost:8080/gax in a web browser.
I tried from Windows 10 host - it works.
Offline zimmerru
« Reply #7 on: April 06, 2020, 07:52:04 PM »
you can work around needing to use the gui for setup mode by defining a setup file with all of the information and starting up GAX with    [quote]    java -jar gax.war -setup gax <setup_file_name>
Here is the template for the setup file (pulled from the Genesys documentation):
[code]Configuration_Server_Host=
Configuration_Server_Port=
Default_Client_Application_Name=
Configuration_Server_Username=
Configuration_Server_Password=
Application_Object_Name=
Database_Server_Type=
Database_Host=
Database_Port=
Database_Name=
Database_Username=
Database_Password=[/code]
Once the GAX starts up you can use Control + C to kill it.  Once this is done the GAX will have all of the information that would have been supplied via the GUI in setup mode.
« Last Edit: April 06, 2020, 08:00:01 PM by zimmerru »
Offline keisim
« Reply #8 on: April 07, 2020, 11:52:39 PM »
This is obviously the correct alternative solution which is described in detail in the current documentation. The question, however, was about [b]remote[/b] gax access in setup mode, and the documentation is silent about this, and this is no exception.
Notwithstanding the above, I have the impression that the quality of documentation has decreased in many areas after it has been made public. Reading some of the chapters I have the impression that individual sections were written by different people without consulting each other... but this can only be my feeling ;)
