" /> Agent logoff authorization - Genesys CTI User Forum
Author Topic: Agent logoff authorization  (Read 2499 times)
Offline Gautham
« on: June 05, 2017, 10:40:41 AM »
Hi friends,
Kindly let me know how to remove or reduce the Agent logoff authorization.
Current setting is taking 30 seconds to logoff.
Kindly help me
Gowthaman G
Re: Agent logoff authorization
« Reply #1 on: June 05, 2017, 02:41:09 PM »
What? Maybe you are using OCS? If so it is normal, it is what OCS takes to remove the agent from already dialed records in Predictive mode.
Offline Gautham
« Reply #2 on: June 05, 2017, 03:14:59 PM »
[quote author=cavagnaro link=topic=10385.msg47130#msg47130 date=1496673669]
ya, we are using OCS. We cannot do anything to customize this?
« Reply #3 on: June 05, 2017, 03:46:43 PM »
Read about the feature on OCS guides.
Don't think you can reduce the time as is what OCS takes to release. Maybe do a normal logoff and avoid calling the OCS logoff? Not sure if native at WDE.
Offline caractacus
« Reply #4 on: June 16, 2017, 07:57:20 PM »
[quote author=Gautham link=topic=10385.msg47131#msg47131 date=1496675699]
The time is dictated by one of the OCS timeout options, call_wait_connected_timeout I think,  check in the outbound reference manual under 'smart logout', that will confirm which one.
Offline Gautham
« Reply #5 on: July 06, 2017, 06:18:51 AM »
It is working .tx
