" /> Error creating bean with name 'bayeuxInitializer.Processor' - Genesys CTI User Forum
Author Topic: Error creating bean with name 'bayeuxInitializer.Processor'  (Read 2940 times)
Offline hieutx
Hi all,
I installed GIR include: http, cassandra, elasticsearch.
When i run cmd: java -Xmx8G -Xms8G -XX:PermSize=512m -jar /opt/gir/gir.jar
i have "Error creating bean with name 'bayeuxInitializer.Processor'".
all file config and file gir.jar same folder.
Please help me.
Re: Error creating bean with name 'bayeuxInitializer.Processor'
« Reply #1 on: June 16, 2017, 05:13:10 AM »
Check used Java version and also post the GIR logs
Odesláno z mého D5803 pomocí Tapatalk
Offline hieutx
« Reply #2 on: June 20, 2017, 07:49:37 AM »
Hi Kubig,
Thanks for response,
I used java version 1.8.0_131 and detail GIR LOG as follow
2017-06-20 14:27:12.228  INFO 31881 --- [          main] c.g.c.application.CloudWebApplication    : Starting CloudWebApplication v8.5.2 on hcmcas01 with PID 31881 (/opt/gir/gir.jar started by root in /root)
2017-06-20 14:27:12.229  INFO 31881 --- [          main] c.g.c.application.CloudWebApplication    : No profiles are active
2017-06-20 14:27:12.374  INFO 31881 --- [          main] ationConfigEmbeddedWebApplicationContext : Refreshing org.springframework.boot.context.embedded.AnnotationConfigEmbeddedWebApplicationContext@22138e16: startup date [Tue Jun 20 14:27:12 ICT 2017]; root of context hierarchy
2017-06-20 14:28:22.932  INFO 31881 --- [          main] f.a.AutowiredAnnotationBeanPostProcessor : JSR-330 'javax.inject.Inject' annotation found and supported for autowiring
2017-06-20 14:28:27.765  INFO 31881 --- [          main] trationDelegate$BeanPostProcessorChecker : Bean 'bayeuxInitializer' of type [class com.genesyslab.web.broker.bayeux.runtime.BayeuxInitializer$$EnhancerBySpringCGLIB$$ecdc0b59] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2017-06-20 14:28:29.368  INFO 31881 --- [          main] trationDelegate$BeanPostProcessorChecker : Bean 'org.springframework.security.config.annotation.configuration.ObjectPostProcessorConfiguration' of type [class org.springframework.security.config.annotation.configuration.ObjectPostProcessorConfiguration$$EnhancerBySpringCGLIB$$31b31ac1] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2017-06-20 14:28:29.806  INFO 31881 --- [          main] trationDelegate$BeanPostProcessorChecker : Bean 'objectPostProcessor' of type [class org.springframework.security.config.annotation.configuration.AutowireBeanFactoryObjectPostProcessor] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2017-06-20 14:28:29.939  INFO 31881 --- [          main] trationDelegate$BeanPostProcessorChecker : Bean 'org.springframework.security.access.expression.method.DefaultMethodSecurityExpressionHandler@4265943e' of type [class org.springframework.security.access.expression.method.DefaultMethodSecurityExpressionHandler] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2017-06-20 14:28:30.263  INFO 31881 --- [          main] trationDelegate$BeanPostProcessorChecker : Bean 'org.springframework.security.config.annotation.method.configuration.GlobalMethodSecurityConfiguration' of type [class org.springframework.security.config.annotation.method.configuration.GlobalMethodSecurityConfiguration$$EnhancerBySpringCGLIB$$e4914f33] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2017-06-20 14:28:30.987  INFO 31881 --- [          main] trationDelegate$BeanPostProcessorChecker : Bean 'methodSecurityMetadataSource' of type [class org.springframework.security.access.method.DelegatingMethodSecurityMetadataSource] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2017-06-20 14:28:31.941  WARN 31881 --- [          main] n.s.ehcache.config.ConfigurationFactory  : No configuration found. Configuring ehcache from ehcache-failsafe.xml  found in the classpath: jar:file:/opt/gir/gir.jar!/lib/ehcache-core-2.6.2.jar!/ehcache-failsafe.xml
2017-06-20 14:28:35.698  INFO 31881 --- [          main] trationDelegate$BeanPostProcessorChecker : Bean 'ehCacheManager' of type [class net.sf.ehcache.CacheManager] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2017-06-20 14:28:36.847  INFO 31881 --- [          main] trationDelegate$BeanPostProcessorChecker : Bean 'cacheManager' of type [class org.springframework.cache.ehcache.EhCacheCacheManager] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2017-06-20 14:28:37.270  INFO 31881 --- [          main] trationDelegate$BeanPostProcessorChecker : Bean 'settingsConfiguration' of type [class com.genesyslab.cloud.SettingsConfiguration$$EnhancerBySpringCGLIB$$7165c69a] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2017-06-20 14:28:41.349  INFO 31881 --- [anager@6d2d90ef] net.sf.ehcache.util.UpdateChecker        : New update(s) found: 2.6.5 [http://www.terracotta.org/confluence/display/release/Release+Notes+Ehcache+Core+2.6]. Please check http://ehcache.org for the latest version.
2017-06-20 14:28:57.294  WARN 31881 --- [          main] ationConfigEmbeddedWebApplicationContext : [b]Exception encountered during context initialization - cancelling refresh attempt: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'bayeuxInitializer.Processor': Injection of autowired dependencies failed;[/b] nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private org.cometd.bayeux.server.BayeuxServer com.genesyslab.web.broker.bayeux.runtime.BayeuxInitializer$Processor.bayeuxServer; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'bayeuxInitializer' defined in URL [jar:file:/opt/gir/gir.jar!/com/genesyslab/web/broker/bayeux/runtime/BayeuxInitializer.class]: Initialization of bean failed; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.springframework.cache.annotation.ProxyCachingConfiguration': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire method: void org.springframework.cache.annotation.AbstractCachingConfiguration.setConfigurers(java.util.Collection); nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'cachingConfiguration': Invocation of init method failed; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'serverSettings': Invocation of init method failed; nested exception is java.lang.IllegalStateException: externalApiUrlV2 must be present in server settings
2017-06-20 14:28:57.478  INFO 31881 --- [          main] .b.l.ClasspathLoggingApplicationListener : Application failed to start with classpath: [jar:file:/opt/gir/gir.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-context-support-4.2.3.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-beans-4.2.3.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-context-4.2.3.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-expression-4.2.3.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-core-4.2.3.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-security-saml2-core-1.0.1.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/opensaml-2.6.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/openws-1.5.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/xmltooling-1.4.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/bcprov-jdk15-1.46.jar!/, jar:file:/opt/gir/gir.jar!/lib/not-yet-commons-ssl-0.3.9.jar!/, jar:file:/opt/gir/gir.jar!/lib/commons-httpclient-3.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/xmlsec-1.5.6.jar!/, jar:file:/opt/gir/gir.jar!/lib/velocity-1.7.jar!/, jar:file:/opt/gir/gir.jar!/lib/esapi-2.0.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/xercesImpl-2.10.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/serializer-2.7.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/xml-resolver-1.2.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-security-oauth2-2.0.8.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-security-core-4.0.3.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/aopalliance-1.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-security-config-4.0.3.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-security-web-4.0.3.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/jackson-mapper-asl-1.9.13.jar!/, jar:file:/opt/gir/gir.jar!/lib/xml-apis-1.4.01.jar!/, jar:file:/opt/gir/gir.jar!/lib/org.json-2.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/ehcache-core-2.6.2.jar!/, jar:file:/opt/gir/gir.jar!/lib/javax.websocket-api-1.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/javax.el-api-2.2.4.jar!/, jar:file:/opt/gir/gir.jar!/lib/javax.el-2.2.4.jar!/, jar:file:/opt/gir/gir.jar!/lib/tiles-api-2.1.4.jar!/, jar:file:/opt/gir/gir.jar!/lib/tiles-core-2.1.4.jar!/, jar:file:/opt/gir/gir.jar!/lib/commons-digester-2.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/commons-beanutils-1.9.2.jar!/, jar:file:/opt/gir/gir.jar!/lib/tiles-jsp-2.1.4.jar!/, jar:file:/opt/gir/gir.jar!/lib/tiles-servlet-2.1.4.jar!/, jar:file:/opt/gir/gir.jar!/lib/commons-fileupload-1.2.2.jar!/, jar:file:/opt/gir/gir.jar!/lib/commons-io-1.4.jar!/, jar:file:/opt/gir/gir.jar!/lib/libphonenumber-4.3.jar!/, jar:file:/opt/gir/gir.jar!/lib/geocoder-1.7.jar!/, jar:file:/opt/gir/gir.jar!/lib/xstream-1.4.7.jar!/, jar:file:/opt/gir/gir.jar!/lib/xmlpull-1.1.3.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/xpp3_min-1.1.4c.jar!/, jar:file:/opt/gir/gir.jar!/lib/restfb-1.6.12.jar!/, jar:file:/opt/gir/gir.jar!/lib/hystrix-core-1.3.16.jar!/, jar:file:/opt/gir/gir.jar!/lib/rxjava-core-0.18.2.jar!/, jar:file:/opt/gir/gir.jar!/lib/archaius-core-0.4.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/commons-configuration-1.8.jar!/, jar:file:/opt/gir/gir.jar!/lib/jsr305-2.0.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/hystrix-metrics-event-stream-1.3.16.jar!/, jar:file:/opt/gir/gir.jar!/lib/protocolmanagerappblock-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/configurationprotocol-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/managementprotocol-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/outboundprotocol-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/reportingprotocol-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/routingprotocol-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/voiceprotocol-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/contactsprotocol-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/openmediaprotocol-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/protocol-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/connection-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/system-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/commons-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/kvlistbinding-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/kvlists-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/warmstandbyappblock-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/webmediaprotocol-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/messagebrokerappblock-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/commonsappblock-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/clusterprotocolappblock-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/switchpolicy-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/logging-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/comappblock-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/jackson2-module-853.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/flexlm-7.2.jar!/, jar:file:/opt/gir/gir.jar!/lib/RegExPlus-1.0.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/bcpkix-jdk15on-1.51.jar!/, jar:file:/opt/gir/gir.jar!/lib/bcprov-jdk15on-1.51.jar!/, jar:file:/opt/gir/gir.jar!/lib/bcmail-jdk15on-1.51.jar!/, jar:file:/opt/gir/gir.jar!/lib/mina-filter-ssl-1.1.7.jar!/, jar:file:/opt/gir/gir.jar!/lib/mina-core-1.1.7.jar!/, jar:file:/opt/gir/gir.jar!/lib/mail-1.4.7.jar!/, jar:file:/opt/gir/gir.jar!/lib/activation-1.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/elasticsearch-1.0.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/lucene-core-4.6.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/lucene-analyzers-common-4.6.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/lucene-codecs-4.6.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/lucene-queries-4.6.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/lucene-memory-4.6.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/lucene-highlighter-4.6.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/lucene-queryparser-4.6.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/lucene-sandbox-4.6.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/lucene-suggest-4.6.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/lucene-misc-4.6.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/lucene-join-4.6.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/lucene-grouping-4.6.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/lucene-spatial-4.6.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/spatial4j-0.3.jar!/, jar:file:/opt/gir/gir.jar!/lib/aws-java-sdk-s3-1.11.36.jar!/, jar:file:/opt/gir/gir.jar!/lib/aws-java-sdk-kms-1.11.36.jar!/, jar:file:/opt/gir/gir.jar!/lib/jmespath-java-1.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/aws-java-sdk-core-1.11.36.jar!/, jar:file:/opt/gir/gir.jar!/lib/ion-java-1.0.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/joda-time-2.8.2.jar!/, jar:file:/opt/gir/gir.jar!/lib/guava-13.0.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/jackson-core-2.7.7.jar!/, jar:file:/opt/gir/gir.jar!/lib/jackson-databind-2.7.7.jar!/, jar:file:/opt/gir/gir.jar!/lib/jackson-annotations-2.7.7.jar!/, jar:file:/opt/gir/gir.jar!/lib/jackson-datatype-json-org-2.7.7.jar!/, jar:file:/opt/gir/gir.jar!/lib/json-20090211_1.jar!/, jar:file:/opt/gir/gir.jar!/lib/jackson-dataformat-cbor-2.7.7.jar!/, jar:file:/opt/gir/gir.jar!/lib/bayeux-api-3.0.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/cometd-java-server-3.0.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/cometd-java-common-3.0.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/jetty-util-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/jetty-jmx-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/cometd-java-websocket-javax-server-3.0.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/cometd-java-websocket-common-server-3.0.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/cometd-java-annotations-3.0.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/javax.inject-1.jar!/, jar:file:/opt/gir/gir.jar!/lib/jsr250-api-1.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/jetty-servlets-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/jetty-continuation-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/jetty-server-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/javax.servlet-api-3.1.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/jetty-http-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/jetty-io-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/jetty-nosql-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/jetty-util-ajax-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/commons-codec-1.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/commons-lang-2.6.jar!/, jar:file:/opt/gir/gir.jar!/lib/httpclient-4.5.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/httpcore-4.4.4.jar!/, jar:file:/opt/gir/gir.jar!/lib/commons-collections-3.2.2.jar!/, jar:file:/opt/gir/gir.jar!/lib/slf4j-api-1.7.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/jcl-over-slf4j-1.7.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/logback-classic-1.1.3.jar!/, jar:file:/opt/gir/gir.jar!/lib/logback-core-1.1.3.jar!/, jar:file:/opt/gir/gir.jar!/lib/astyanax-1.56.44.jar!/, jar:file:/opt/gir/gir.jar!/lib/uuid-3.2.jar!/, jar:file:/opt/gir/gir.jar!/lib/astyanax-cassandra-1.56.44.jar!/, jar:file:/opt/gir/gir.jar!/lib/netty-3.2.4.Final.jar!/, jar:file:/opt/gir/gir.jar!/lib/org.apache.servicemix.bundles.commons-csv-1.0-r706900_3.jar!/, jar:file:/opt/gir/gir.jar!/lib/concurrentlinkedhashmap-lru-1.3.jar!/, jar:file:/opt/gir/gir.jar!/lib/astyanax-contrib-1.56.44.jar!/, jar:file:/opt/gir/gir.jar!/lib/eureka-client-1.1.110.jar!/, jar:file:/opt/gir/gir.jar!/lib/jsr311-api-1.1.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/servo-core-0.4.36.jar!/, jar:file:/opt/gir/gir.jar!/lib/annotations-2.0.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/jersey-bundle-1.9.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/jersey-apache-client4-1.8.jar!/, jar:file:/opt/gir/gir.jar!/lib/jersey-client-1.8.jar!/, jar:file:/opt/gir/gir.jar!/lib/jersey-core-1.8.jar!/, jar:file:/opt/gir/gir.jar!/lib/astyanax-core-1.56.44.jar!/, jar:file:/opt/gir/gir.jar!/lib/astyanax-queue-1.56.44.jar!/, jar:file:/opt/gir/gir.jar!/lib/astyanax-thrift-1.56.44.jar!/, jar:file:/opt/gir/gir.jar!/lib/high-scale-lib-1.1.2.jar!/, jar:file:/opt/gir/gir.jar!/lib/snappy-java-1.0.4.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/jackson-core-asl-1.9.2.jar!/, jar:file:/opt/gir/gir.jar!/lib/jettison-1.2.jar!/, jar:file:/opt/gir/gir.jar!/lib/stax-api-1.0.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/astyanax-recipes-1.56.44.jar!/, jar:file:/opt/gir/gir.jar!/lib/astyanax-entity-mapper-1.56.44.jar!/, jar:file:/opt/gir/gir.jar!/lib/persistence-api-1.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/cassandra-all-1.2.11.jar!/, jar:file:/opt/gir/gir.jar!/lib/lz4-1.1.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/compress-lzf-0.8.4.jar!/, jar:file:/opt/gir/gir.jar!/lib/commons-cli-1.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/antlr-3.2.jar!/, jar:file:/opt/gir/gir.jar!/lib/antlr-runtime-3.2.jar!/, jar:file:/opt/gir/gir.jar!/lib/stringtemplate-3.2.jar!/, jar:file:/opt/gir/gir.jar!/lib/antlr-2.7.7.jar!/, jar:file:/opt/gir/gir.jar!/lib/avro-1.4.0-cassandra-1.jar!/, jar:file:/opt/gir/gir.jar!/lib/jline-1.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/json-simple-1.1.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/snaptree-0.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/jbcrypt-0.3m.jar!/, jar:file:/opt/gir/gir.jar!/lib/metrics-core-2.2.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/libthrift-0.7.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/cassandra-thrift-1.2.11.jar!/, jar:file:/opt/gir/gir.jar!/lib/jamm-0.2.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/netty-3.6.6.Final.jar!/, jar:file:/opt/gir/gir.jar!/lib/metrics-core-3.1.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/metrics-spring-3.0.3.jar!/, jar:file:/opt/gir/gir.jar!/lib/metrics-core-3.0.2.jar!/, jar:file:/opt/gir/gir.jar!/lib/metrics-healthchecks-3.0.2.jar!/, jar:file:/opt/gir/gir.jar!/lib/metrics-annotation-3.0.2.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-aop-4.2.3.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/metrics-servlets-3.1.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/metrics-healthchecks-3.1.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/metrics-json-3.1.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/metrics-jvm-3.1.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/metrics-jetty9-3.1.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/metrics-servlet-3.1.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-boot-starter-web-1.3.0.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-boot-starter-1.3.0.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-boot-1.3.0.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-boot-autoconfigure-1.3.0.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-boot-starter-logging-1.3.0.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/jul-to-slf4j-1.7.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/log4j-over-slf4j-1.7.5.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-boot-starter-validation-1.3.0.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/tomcat-embed-el-8.0.28.jar!/, jar:file:/opt/gir/gir.jar!/lib/hibernate-validator-5.2.2.Final.jar!/, jar:file:/opt/gir/gir.jar!/lib/validation-api-1.1.0.Final.jar!/, jar:file:/opt/gir/gir.jar!/lib/jboss-logging-3.3.0.Final.jar!/, jar:file:/opt/gir/gir.jar!/lib/classmate-1.1.0.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-web-4.2.3.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-webmvc-4.2.3.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-boot-starter-jetty-1.3.0.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/jetty-webapp-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/jetty-xml-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/jetty-servlet-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/jetty-security-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/websocket-server-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/websocket-common-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/websocket-api-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/websocket-client-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/websocket-servlet-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/javax-websocket-server-impl-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/jetty-annotations-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/jetty-plus-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/jetty-jndi-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/javax.annotation-api-1.2.jar!/, jar:file:/opt/gir/gir.jar!/lib/asm-5.0.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/asm-commons-5.0.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/asm-tree-5.0.1.jar!/, jar:file:/opt/gir/gir.jar!/lib/javax-websocket-client-impl-9.2.14.v20151106.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-boot-starter-actuator-1.3.0.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-boot-actuator-1.3.0.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/spring-boot-starter-security-1.3.0.RELEASE.jar!/, jar:file:/opt/gir/gir.jar!/lib/lombok-1.16.10.jar!/, jar:file:/opt/gir/gir.jar!/lib/snakeyaml-1.16.jar!/]
2017-06-20 14:28:58.039 ERROR 31881 --- [          main] o.s.boot.SpringApplication              : Application startup failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'bayeuxInitializer.Processor': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private org.cometd.bayeux.server.BayeuxServer com.genesyslab.web.broker.bayeux.runtime.BayeuxInitializer$Processor.bayeuxServer; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'bayeuxInitializer' defined in URL [jar:file:/opt/gir/gir.jar!/com/genesyslab/web/broker/bayeux/runtime/BayeuxInitializer.class]: Initialization of bean failed; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.springframework.cache.annotation.ProxyCachingConfiguration': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire method: void org.springframework.cache.annotation.AbstractCachingConfiguration.setConfigurers(java.util.Collection); nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'cachingConfiguration': Invocation of init method failed; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'serverSettings': Invocation of init method failed; nested exception is java.lang.IllegalStateException: externalApiUrlV2 must be present in server settings
at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.postProcessPropertyValues(AutowiredAnnotationBeanPostProcessor.java:334) ~[spring-beans-4.2.3.RELEASE.jar!/:4.2.3.RELEASE]
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1214) ~[spring-beans-4.2.3.RELEASE.jar!/:4.2.3.RELEASE]
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:543) ~[spring-beans-4.2.3.RELEASE.jar!/:4.2.3.RELEASE]
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482) ~[spring-beans-4.2.3.RELEASE.jar!/:4.2.3.RELEASE]
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306) ~[spring-beans-4.2.3.RELEASE.jar!/:4.2.3.RELEASE]
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230) ~[spring-beans-4.2.3.RELEASE.jar!/:4.2.3.RELEASE]
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302) ~[spring-beans-4.2.3.RELEASE.jar!/:4.2.3.RELEASE]
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:202) ~[spring-beans-4.2.3.RELEASE.jar!/:4.2.3.RELEASE]
at org.springframework.context.support.PostProcessorRegistrationDelegate.registerBeanPostProcessors(PostProcessorRegistrationDelegate.java:240) ~[spring-context-4.2.3.RELEASE.jar!/:4.2.3.RELEASE]
at org.springframework.context.support.AbstractApplicationContext.registerBeanPostProcessors(AbstractApplicationContext.java:686) ~[spring-context-4.2.3.RELEASE.jar!/:4.2.3.RELEASE]
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:522) ~[spring-context-4.2.3.RELEASE.jar!/:4.2.3.RELEASE]
at
Please help me.
« Reply #3 on: September 29, 2018, 08:07:11 PM »
Hi!
How did you solve this?
