" /> What if I'll delete scripts using CME, instead of IRD? (Both v7.5) - Genesys CTI User Forum
Author Topic: What if I'll delete scripts using CME, instead of IRD? (Both v7.5)  (Read 2365 times)
Offline Gef Buneri
  • Madness is just a point of view.
Hi all, as in object, 'cause never did so, using IRD only to delete strategies.
Deleting from CME deletes all references? (IRD, Config DB with BLOB, etc.) or CME is just for organizing?
Best regards,
Gef.
Offline hsujdik
Re: What if I'll delete scripts using CME, instead of IRD? (Both v7.5)
« Reply #1 on: October 27, 2017, 02:13:28 PM »
if you delete a "Simple Routing" script from CME, you delete the reference and bytecode, but the uncompiled/editable version of the Strategy will remain in IRD database (assuming you saved the strategy to the database), but not directly accessible.
Offline Gef Buneri
« Reply #2 on: October 27, 2017, 02:29:30 PM »
Thanks hsu, so in CME the object exists only for referencing.
Regards.
« Reply #3 on: October 27, 2017, 03:46:35 PM »
In CME is the ID but the content of that ID is or on a zcf file or in a database.
So if you delete from CME you delete only the ID but not its content(logic) and could be rescued from database or zcf file.
While deleting from IRD deletes everything, logic and ID.
Offline hsujdik
« Reply #4 on: October 27, 2017, 04:32:09 PM »
[quote author=cavagnaro link=topic=10717.msg48697#msg48697 date=1509119195]
[quote author=Gef Buneri link=topic=10717.msg48696#msg48696 date=1509114570]
Regards.
Actually, the code that URS uses for routing also is in the Script object (the "bytecode" option in the "strategy" section of the annex). If you delete from CME, URS may not route the interactions, but they can be recovered from zcf or the IRD DB.
Offline terry
« Reply #5 on: October 28, 2017, 04:30:36 AM »
In such case you will left "hanged" somewhere rbn file (either as file in file system or as record in Database).
rbn files are too big to store them in regular way in CME - they handled as separate entitites and by IRD only.
Even bytecode is too big really and it not even propagated to any CME client except URS.
Offline Gef Buneri
« Reply #6 on: November 13, 2017, 02:27:06 PM »
Thank you very much, guys, the point perfectly clear. I use IRD to delete strategies, to delete all references and the blob on db, but I was just wandering if there was a "bulk" method to delete more strategies at once; I'll continue to delete one strategy per time :)
Regards.
