" /> ISuite Bug - Genesys CTI User Forum
Author Topic: ISuite Bug  (Read 4763 times)
Galen Garrison
ISuite Bug
Beware. If there is a pipe '|' in the from: email address of an inbound email, EventMgr.exe will use up all the CPU and discontinue processing emails. The solution is to remove the bad email from the inbound folder, open NT task manager, and kill EventMgr.exe.
Regards,
Galen
Sunny Tampa Bay, FL, USA
Marked as best answer by on Today at 04:32:40 AM
jeff
ISuite Bug
  • Undo Best Answer
  • I have never heard of the pipe in the email address. Is it even legal?
    Regards,
    Jeff
    amezouj
    ISuite Bug
    NO, email adress is [az] [A] [_] [09] [.]
    Ahmed M
    ISuite Bug
    I tried to replicate the problem but failed to do so. On what version of the product did you find it?
    Ahmed Mubaraki
    Matt Lehrer
    ISuite Bug
    5.1.609
