" /> SIP protocol issue ? missing first seconds of MCP treatment - Genesys CTI User Forum
Author Topic: SIP protocol issue ? missing first seconds of MCP treatment  (Read 2122 times)
Offline GregorV
When a call arrives on SIP-Server and a treatment is started, then the first seconds are cut off. We have seen a [b]reinvite[/b] from outside after there was the [b]established[/b] from MCP. So the audiofile is started while there are new negitiations for the connection while the caller hears nothing. We have two possibilities to send a call to SIP-Server. A direkt dial from an external number: no issue BUT if the call comes from a network SIP-Server via servicenumber then we see the issue. A workaround is to play 100ms silence before starting the regular treatment. Is this problem known and is there a 'cleaner' solution ?
Offline hsujdik
Re: SIP protocol issue ? missing first seconds of MCP treatment
« Reply #1 on: April 23, 2018, 12:07:26 PM »
You may try to set reuse-sdp-on-reinvite to "true" on the msml trunk to check if that helps.
« Reply #2 on: June 14, 2018, 08:23:15 PM »
Where you able to fix this issue?
