" /> Meaning of Forced Off in CCPulse? - Genesys CTI User Forum
Author Topic: Meaning of Forced Off in CCPulse?  (Read 2623 times)
Offline wim81
« on: September 25, 2018, 07:45:51 AM »
Hi Everyone,
Can anyone tell me the meaning of the term Forced Off in CCPulse?
Thank you
Offline pdavid
Re: Meaning of Forced Off in CCPulse?
« Reply #1 on: September 25, 2018, 08:08:38 PM »
Not sure I understand, can you elaborate a bit on this term? I've never heard of that term, however my knowledge of CCPulse is the frontend of it, basically agent/queue stats, and building templates. Perhaps this is something that is deeper than my understanding.
« Reply #2 on: September 25, 2018, 09:11:24 PM »
Agree, that is not a Status, Action nothing named like that at Genesys Events, so, from where do you get it? Maybe someone put that name as a column in a report? If so, check the metric definition of that column as only you would be able to answer that.
Offline catanirex
« Reply #3 on: September 27, 2018, 02:43:48 PM »
Maybe you mean the stat parameter Calls_Forced_Off?
Which is TotalNumber CallForwarded measured for Agent, Place, GroupAgents, GroupPlaces
« Reply #4 on: September 27, 2018, 02:45:12 PM »
On which report does that column appear?
Offline catanirex
« Reply #5 on: September 28, 2018, 08:09:35 AM »
In Pulse it 's in the Agent KPIs
For CCP I do not know if its in some pre-designed template? But if the stat is defined on statserver, you can always add it to your template.
