" /> ORS Cluster is not configured - Genesys CTI User Forum
Author Topic: ORS Cluster is not configured  (Read 2052 times)
Offline Filippe
« on: October 22, 2018, 06:09:57 PM »
Hi
Im facing this problem with Orquestration Server 8.1.400.77
"This node is not operational - ORS Cluster is not configured"
I can not route an interaction because of ORS, it seems I could not configure the cluster well
I have already set up the transaction and cassandra .yalm file but it does not work!
https://imgur.com/a/Jxo2lAM
https://imgur.com/a/SoWqtOb
https://imgur.com/a/fAVIzJx
Anybody can help me to solve it?
thanks
Offline hsujdik
Re: ORS Cluster is not configured
« Reply #1 on: October 22, 2018, 06:53:59 PM »
On the cluster section, the Key should be the application name and the value some "site" name. Also, since your transaction name is not ORS, it should be in the Command Line parameters of the Start Info tab of Orchestration Server. In your case, you should add '-cluster "ORS CLuster"' (avoid using spaces.....)
Offline Filippe
« Reply #2 on: October 22, 2018, 07:00:37 PM »
Hi!!!
Yes it is on command Line and i change the name of the cluster Without spaces "ORS_Cluster"
Offline hsujdik
« Reply #3 on: October 22, 2018, 07:09:31 PM »
Did you also enter a name (any name) on the value of the key "OR_Server" for the cluster section in that transaction/list?
Offline Filippe
« Reply #4 on: October 22, 2018, 07:30:30 PM »
Yes, the value "LaCaja"
https://imgur.com/a/1waeJg1
also change the name in the .yalm in cassandra!
« Reply #5 on: October 23, 2018, 07:21:22 AM »
From provided screenshots it seems your Transaction list is configured with name "ORS_CLuster", but the start-up parameter is configured with value "-cluster ORS_Cluster" - due to the ORS looks for objects using case-sensitive, it will fails as there is no object "ORS_Cluster" at all. Repair/Fix the name of the transaction list and restart ORS, than it should work as expected.
