" /> Pulse Gax plugin - Genesys CTI User Forum
Author Topic: Pulse Gax plugin  (Read 2303 times)
Offline Django
Pulse Gax plugin
« on: September 01, 2020, 09:06:58 AM »
Hi everyone,
I have installed pulse as gax plugin. After copying jar files from Pulse root directory to  /webapp/WEB-INF/lib. I am not able to access Gax url.
Error- Service Unavailable.
Pulse v8.5.103
Gax v9.0.100.66
Offline catanirex
Re: Pulse Gax plugin
« Reply #1 on: September 01, 2020, 10:29:03 AM »
From version 9 Pulse is no longer a plugin to GAX. It is a standalone application.
So yoneed to select different ports for GAX and Pulse and carefully follow Pulse 9 installation/migration guide
Offline Django
« Reply #2 on: September 01, 2020, 11:24:25 AM »
Hi Catanirex,
Thanks for quick response. It is our requirement from top to install Pulse as GAX plugin. Please let me know if you have the same. Thanks
Offline catanirex
« Reply #3 on: September 01, 2020, 12:19:06 PM »
If you need it as GAX plugin you need to install latest 8.5 Pulse and not do any upgrades since that version is the last 8.5 version
Version 9 is standalone only.
Offline Django
« Reply #4 on: September 01, 2020, 12:37:52 PM »
I have installed Pulse v8.5.103
Offline catanirex
« Reply #5 on: September 01, 2020, 12:56:11 PM »
So sorry! I mixed it up and read Pulse 9 and GAX 8.5...
Have you checked that this combination should work?
« Reply #6 on: September 01, 2020, 02:54:07 PM »
I do not think that GAX 9.X is supported with Pulse 8.5.X. Check the system-level guide as there you can see you need GAX 8.5.2.
