" /> WDE Class Source file - Genesys CTI User Forum
Author Topic: WDE Class Source file  (Read 1637 times)
Offline PFCCWA
« on: January 15, 2022, 09:35:17 PM »
i have customized WDE using interaction samples however misplaced the project/solution.
At the moment i have the module-config, DLL, interactionworkspace.exe.cfg and a language file.
Is there a way to retrieve it, or at least the class source file code through the files above?
thanks,
Offline gen_rtfm
Re: WDE Class Source file
« Reply #1 on: January 15, 2022, 11:28:07 PM »
The only option I can think of is a decompiler, something like dotpeek.
Not sure if that actually creates usable source files though, I have not used it myself.
It seems a bit odd to misplace the sources, but since this answer is simply a google away I choose to trust your intentions blindly [emoji41]
Br
Skickat från min Mi MIX 3 5G via Tapatalk
