" /> config db-direct-connection - Genesys CTI User Forum
Author Topic: config db-direct-connection  (Read 2244 times)
Offline abdel
« on: January 19, 2022, 09:40:40 AM »
Is there a way to configure DAP for statserver to access a database directly using the section db-direct-connection?
Genesys documentation doesn't provide details, other jdbc config are related either to infomart, GRS...
Any help is appreciated
Best regards
Offline catanirex
Re: config db-direct-connection
« Reply #1 on: January 20, 2022, 03:19:00 PM »
That section should be configured on StatServer application object to be able to use SS without a Genesys DBserver.
So, add the section on SS, configure the DAP that is connected to SS as a normal DAP for DBServer use (not jdbc) and install correct db drivers on the server as described on:
https://docs.genesys.com/Documentation/Options/Current/RTME/Stat_Server-db-direct-connection
