" /> Sending custom UUI string using IRD 8.1.4 and Sipserver 8.1.1 - Genesys CTI User Forum
Author Topic: Sending custom UUI string using IRD 8.1.4 and Sipserver 8.1.1  (Read 1276 times)
Offline Gef Buneri
  • Madness is just a point of view.
Hi all, hope everything's fine out there.
I'm trying to understand how to send a custom string using UUI from a strategy to an external SIP Trunk.
Reading in the forum and in the documentation I got that I should set something in the sipserver options, maybe:
sip-pass-from-parameters
sip-pass-refer-headers
This options at the moment are empty.
And then from strategy I have to attach a value plus some parameters, but I'm not sure on the method and the syntax.
Someone could help me, please, with examples, maybe?
Best regards,
Gef
« Last Edit: May 10, 2023, 11:12:58 AM by Gef Buneri »
vaunmac
Re: Sending custom UUI string using IRD 8.1.4 and Sipserver 8.1.1
« Reply #1 on: June 03, 2023, 02:52:17 AM »
hi Gef
Sorry  kept meaning to come back to this thread but only just got around to it.
The following was very helpful to me when I set up UUI Data to/from Engage about a year ago:
https://joeywhelan.blogspot.com/2014/03/sip-uui-integration-with-genesys-routing.html
If Joey's on here still - thanks! :)
Offline Gef Buneri
« Reply #2 on: June 08, 2023, 08:44:31 AM »
Thank you very much for your time, Nonny, I'll check it for sure.
