" /> [SOLVED] Genesys Secure Pack mandatory for HTTPS Web Services IRD/URS 8.1 - Genesys CTI User Forum
Author Topic: [SOLVED] Genesys Secure Pack mandatory for HTTPS Web Services IRD/URS 8.1  (Read 3430 times)
Offline Gef Buneri
  • Madness is just a point of view.
Hello all, hope everything's fine out there.
I'm trying to figure out how to call a HTTPS URL (REST API using a HTTP POST with anonymous auth), but I feel something is missing. Until now I get that:
- One must configure the WEB options session within URS with the certificate specs (a certificate is mandatory?) and HTTP port infos
What else? I have read that to enable HTTPS web services calls from IRD, the Genesys Security Pack libraries should be installed, and their path configured on URS process side.
Could please someone help out? docs aren't perfectly clear on this, they mainly point to HTTP, not HTTPS calls.
Best regards,
Gef
« Last Edit: June 27, 2023, 11:03:17 AM by Gef Buneri »
vaunmac
Sorry it's been a few years but I can say 100% the security pack is not mandatory under Windows Server.  What is important is to check  TLS/SSL level support at the OS level too.
I don't recall if I put the cert thumbprint string in URS options or just got the third party cert and imported into the local computer cert store
Offline Gef Buneri
Thank you Nonny. Sorry, I forgot to specify that this is a linux server.
vaunmac
Ahhh then I vaguely remember support telling me back in 2015 that the pack is required for Linux
Offline Gef Buneri
Installed Genesys Security Pack on Linux, but even if all seems correctly configured, when trying to consume a HTTPS Web Service from a strategy, I obtain this message:
Unable to load resource 'libgsecurity_openssl_64.so', error code 'Unable to load any module file'
The file does exist and the PATH environmental variable is correctly configured pointing to the path where the file is in.
I installed the Security Pack in the same host as URS.
It seems I should add the path to the URS process too, but not sure how to do so.
Any clue?
Best,
Gef
« Last Edit: June 21, 2023, 08:19:37 PM by Gef Buneri »
Which environment is URS application using? I usually at the env for Genesys apps in lca script
Offline terry
By PATH you mean PATH or LD_LIBRARY_PATH?
Offline Gef Buneri
I think the problem is that in the LD_LIBRARY_PATH the libraries path isn't present; am I right?
/$ printenv
XDG_SESSION_ID=4311
HOSTNAME=sip-server-01
SHELL=/bin/bash
HISTSIZE=1000
SSH_CLIENT=***.***.***.*** **** ***
USER=****
LD_LIBRARY_PATH=/usr/lib/oracle/19.6/client64/lib
TNS_ADMIN=/usr/lib/oracle/19.6/client64/network/admin
MAIL=/var/spool/mail/****
PATH=/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/usr/lib/oracle/19.6/client64/bin
PWD=/
LANG=en_GB.UTF-8
HISTCONTROL=ignoredups
SHLVL=1
HOME=/home/tscs
LOGNAME=****
SSH_CONNECTION=***.***.***.*** **** ***.***.***.*** ***
LESSOPEN=||/usr/bin/lesspipe.sh %s
XDG_RUNTIME_DIR=/run/user/10224
ORACLE_HOME=/usr/lib/oracle/19.6/client64
_=/usr/bin/printenv
OLDPWD=/home/tscs
« Last Edit: June 23, 2023, 06:15:58 AM by Gef Buneri »
Marked as best answer by cavagnaro on June 29, 2023, 02:34:21 AM
Offline terry
It is one of most common reason up to my knowledge.
Also it might depends from how it set and how URS is started.
I mean for example that if URS is started through LCA then LD_LIBRARY_PATH probably must be set in .bashrc and not in .bash_profile
Offline hsujdik
You can see it getting the process ID of URS and then checking the file /proc/<process id>/environ
This way you can tell if URS was initialized with the proper environment variables.
And, like terry said, if you are initializing through Management Layer (SCI, GA, GAX, mlcmd, etc), URS will inherit LCA's environment variables at the time it was started up.
Offline Gef Buneri
Hi everyone, I have checked further and in the snippet I posted in my previous comment the variable is missing because the environment is relative to my user, but for the genesys user the variable is correctly configured.
However, at this point I'm doubting I am using the wrong approach because the process is started from a different environment, SCI.
I wonder if it is possible to introduce the variable directly into the application using the configuration manager, in the URS's start info page?
As showed in Genesys documentation:
Example 2:
Command Line Arguments: LD_LIBRARY_PATH=/home/OCS:$LD_LIBRARY_PATH ./cmserver -host HostName -port 8100 -app "OCS_Name" -l "LicensePort@LicenceHost"
At the moment in CME the command line arguments string looks like this: -host [CFGSERVER] -port [CFGSERVERPORT] -app "urs" -l [PORT]@[LICENCESERVER]
So I was thinking of adding the value directly in the string, this way:  LD_LIBRARY_PATH=[LIBSPATH]:$LD_LIBRARY_PATH -host [CFGSERVER] -port [CFGSERVERPORT] -app "urs" -l [PORT]@[LICENCESERVER]
Best and thank you very much for your time,
Gef
« Last Edit: June 26, 2023, 10:01:36 AM by Gef Buneri »
As said, if you are using SCI you are using LCA. Better insert the env variables there ;)
Offline Gef Buneri
Thanks Cav <3  you mean in the lca_custom.cfg file?
Btw, the string as I wrote it in my previous example would work if used exactly whis way?
« Last Edit: June 26, 2023, 12:01:34 PM by Gef Buneri »
Offline Gef Buneri
Btw, as stated by Terry, setting the url in .bashrc seems to have worked.
Great! Will follow that advice as well
