" /> Cant login on Pulse - Genesys CTI User Forum
Author Topic: Cant login on Pulse  (Read 971 times)
Offline espancagenesys
Cant login on Pulse
« on: June 02, 2023, 04:55:58 PM »
Im having a problem while trying to log in on pulse. I cant log in with new users or even if I reset the password for old users. Seens like that Pulse doesnt recognize the password.
I tried to create a new user from 0 and granted the necessary permissions, but when try access, theres no success:
17:09:46.297 Trc 24205 Notification : Object [CfgAgent], name [000000], DBID: [8376] is created at server (39656289)
17:09:46.297 Trc 24308 Message MSGCFG_OBJECTADDED2 (0x1ccffdf0) generated
  MSGCFG_OBJECTADDED2
  attr: IATRCFG_FOLDERDBID          value:  1533
  attr: IATRCFG_HISTORYLOG          value:  0
  attr: SATRCFG_OBJECT              value:  "<... 346 bytes ...>"
  attr: IATRCFG_OBJECTTYPE          value:  3 [CfgPerson]
  attr: IATRCFG_TIMESTAMP          value:  1685650186
  attr: IATRCFG_UNSOLEVENTNUM      value:  39656289
  attr: IATRCFG_REQUESTID          value:  0
17:38:24.964 Std 22122 Client 24 failed to get authorization. Name [default], type [SCE], user [000000], address [10.113.97.21:40490]. Authentication type : [master]. Reason : Authentication failed, user name or password is incorrect
17:38:24.964 Std 23500 Configuration Server Error : Error  [CFGLoginIncorrect], object [CfgPerson], property [password] Description Authentication failed, user name or password is incorrect
17:38:24.964 Trc 04542 Message MSGCFG_ERROR sent to 24 ( '')
  MSGCFG_ERROR
  attr: IATRCFG_ERRORCODE          value:  6357764
  attr: SATRCFG_DESCRIPTION        value:  "Authentication failed, user name or password is incorrect"
  attr: IATRCFG_REQUESTID          value:  2
Theres no external ID.
If i try with an old user reseting its password, cant login with the new password, but if I rollback to the old pass, everything is ok.
My suspect is that the Pulse configuration server is not working properly, because when I try to log in in another applications (like CME, G.A, Speechminer), the log in is possible.
Is there another troubleshooting that I can do? ANy idea to fix this?
Thx
« Last Edit: June 02, 2023, 05:25:19 PM by espancagenesys »
Offline nonny
Re: Cant login on Pulse
« Reply #1 on: June 02, 2023, 09:41:58 PM »
I can't help but wonder if you've actually got multiple instances of confserv/confserv proxy pointing at different DBs?
