" /> Adding Agents to an Agent Group without Conf Mgr - Genesys CTI User Forum
Author Topic: Adding Agents to an Agent Group without Conf Mgr  (Read 4882 times)
Daniel Alvers
I am looking for a way to add/remove Agents from Agent Groups without using Conf Mgr. Bascially I need to give my Agents the ability to move themselves between groups without placing our overall infastructure at this fingertips.
Any suggestions would be appreicated.
Short
  • By creating a special Access Group in Configuration Manager, you can "hide" everything except, for example, the Person and Agent Groups folders for persons belonging to this group.
    I have done that several times. The problem is that if the person is an agent, you need to have a separate CMEaccount to avoid changing the Users Acces groups right.
    You must also configure some Security permissions so that Users cannot log in to CME.
    Dave
  • You could also use the Config SDK to create a basic web (or other) app that allows them to do this. You would, however, have to actually license that SDK (and the runtime) to do it...
    Daniel Alvers
  • Thanks for the feedback. With the Config SDK could you tell me what the actual Genesys Product is called? I have heard of the Desktop SDK, is this the same thing?
    Eisa
  • youcan use the Genesys Interface Server (GIS) configuration SDK to do this
