" /> How to get Extarnal Agent Reply ... - Genesys CTI User Forum
Author Topic: How to get Extarnal Agent Reply ...  (Read 3427 times)
Vivek
I have a question I appreciate anyone can provide a suggestion or idea.
I want to send email back and forth between Agent and External Agent. So I have developed a process to handle this task. But I need to capture the full email body every time when the reply comes from External Agent.
I can see the full email history in Agent Desktop history tab. My question is is there any easy way I can get the full email body (Customer question, Agent’s question to External Agent, and External Agent's reply)? and save it to in a text file.
Thanks in advance.
Vivek
I just want to add few info:
We are using ICS65 and Database is Oracle8i, Agent desktop was developed using VB6.0.
Marked as best answer by on Today at 08:05:35 AM
Paul
Re: How to get Extarnal Agent Reply ...
« Reply #2 on: October 20, 2006, 06:27:44 AM »
  • Undo Best Answer
  • you could write a program in VB or VBA to do this, make sure you activate the outlook object model, then search on net for sample code.  it took me a couple of yours to do, not too difficult.
    Paul.
