" /> How to get Skill definition of VAG on a fly? - Genesys CTI User Forum
Author Topic: How to get Skill definition of VAG on a fly?  (Read 3544 times)
I am in serious need of retrieving skill and value used to define a VAG from inside the strategy.
I have a strategy A and inside it, I need to retrieve the skill and value uses by virtual agent group VAG_1. How can this be done?
ecki
  • Hi,
    So I think, you have to use stored procedure for this. Join two table "cfg_group.dbid" and "cfg_flex_prop.objec_dbid" and use criteria "cfg_group.name=input value","cfg_flex_prop.objext_type=5","cfg_flex_prop.prop_name='script'" and the returning variable should be filled from cfg_flex_prop.prop_value".
    Offline makkerc
    Re: How to get Skill definition of VAG on a fly?
    « Reply #2 on: February 07, 2011, 04:33:01 PM »
  • Vic, did you manage to get the SQL Statement?
    I'm loking for the same!
    Cheers!!
