" /> Writing Strategy - Genesys CTI User Forum
Author Topic: Writing Strategy  (Read 3646 times)
Regi
Writing Strategy
Hi, I would like to learn strategy writing. Is there any tutorials or any web site I can go and learn it.
Thanks, Regi
Tony Tillyer
Writing Strategy
I doubt that you would be able to obtain any Genesys training material without attending the relevant course. I do not believe there are currently any guides to Routing although I have it on good authority that an authorised "Genesys for Dummies" is in the making at present.
Tony.
Marked as best answer by on July 17, 2025, 01:51:12 PM
Kevin
Writing Strategy
  • Undo Best Answer
  • If you have access to the Support site, they have developed a PDF with sample strategies in it.
    Though I do agree with Tony there are usually certain things that are covered in classes that are not listed (or apparent) in the documentation.
