" /> Windows Services - Genesys CTI User Forum
Author Topic: Windows Services  (Read 3704 times)
sitto
Windows Services
Hi everybody,
I installed Tserver but I didn't add it to windows services.
How do I manually add Tserver service to windows service?
My OS is Windows 2003.
Thank you very much,
sitto
Beancurd
Windows Services
  • You could reinstall the TServer and make sure 'install as service' box is ticked......
    Or get a pet Windoze administrator to do it for you if you cant do it. I dont use Win2003 so I cant give step by step instructions.
    B
    ecki
    Windows Services
  • I think there is one utility from MS Windows "Service.exe" which you can use to register any application as service. Like service.exe "serivce name" "service key" "path to application/binary.exe"
    Check on MS web server.
    Windows Services
  • My suggestion would be just to re un the install package (setup.exe) , because it will be the easiest thing to do and will take you less than a minute.
