" /> CallType Filter in CCPulse - Genesys CTI User Forum
Author Topic: CallType Filter in CCPulse  (Read 5151 times)
Ben
Hello
I need a way to filter all calls with calltype = 2 in CCPulse.
Ben
There is no simple way of doing this.
Here is a dumb way:
1. if you are using URS, add attach data to the interaction with calltype and then filter on the attached data.
here is a bit better way:
2. create your own stat with MainMask CallInbound, but you will need to be a bit more creative with define the Actions and so on.
Of course it depends on how many statistics you have if one: create a new one. If all and if you have URS, I would think about adding attach data.
3. Of course, for those who do not have a URS and a budget for one, just modify StarterApp to issue RequestAttachData on for example EventQueued or something and then just make it Register with a Queue. This way, whenever call enters a call center, StarterApp will attach calltype as an attachdata to it, thus allowing you to do what you want without buying a URS. Needless to say, starterapp is just for testing get somebody to develop a simple server to do that for you...
Here I am, talking about developing something that already exists probably...
ecki
Calls with Attribure CallType = 2 are Inbound calls. So you do not need any filter for this, just use Statistics where MainMask = "CallInbound".
Marked as best answer by on Today at 08:12:33 PM
Tony Tillyer
  • Undo Best Answer
  • ...D'oh!
