" /> Custom Server Error - Genesys CTI User Forum
Author Topic: Custom Server Error  (Read 2566 times)
toumtoum7
Custom Server Error
« on: August 30, 2006, 08:11:38 AM »
Hi all,
I have a problem with my Custom Server. Indeed, each week, there is this error :
16:12:18.832 Trc 20007 RCP Call: EXECUTE (client=13, ref_id=265171, internal_id=21678)
16:12:18.832 Trc 20010 RCP Parameter 1: R_CUSTOMER_PROCEDURE
16:12:18.832 Trc 20010 RCP Parameter 2: ANI='631445655'
16:12:18.832 Trc 20010 RCP Parameter 3: CodSI='003'
16:12:18.832 Trc 20010 RCP Parameter 4: CodStruct='021400'
16:12:18.832 Trc 20010 RCP Parameter 5: IdCLi='Null'
16:12:18.851 Std 21002 EXCEPTION in R_CUSTOMER_PROCEDURE(...) of your RCP shared object/library. RCP function call (EXECUTE,R_CUSTOMER_PROCEDURE,...) was ignored
So, I have to restart it each time !
I don't know if there is a relation, but the "internal_id" variable is between 21000 and 22000. And when I restart the Custom Server, internal_id=0.
Is anybody know what represents this variable ?
toumtoum
Pter K.
Re: Custom Server Error
« Reply #1 on: August 31, 2006, 03:04:40 AM »
  • Custom Server is called as a DLL: talk to a programmer who wrote your custom server on how it is handling itself after execution completes. Does the instance destroy itself or not? I think that you keep old instances of DLL and generate a new one each time. How is your DLL compiled? Is it static?
