" /> Populating COMMENT_ field in person object - Genesys CTI User Forum
Author Topic: Populating COMMENT_ field in person object  (Read 3256 times)
Offline Scottyjohn
« on: October 09, 2006, 02:47:12 PM »
Hi all,
I am looking to find a way to populate the COMMENT_ field in the CFG_PERSON table with a string.  I cant access it directly as our solution is a managed service and therefore we only have CME and read only access to the CFG DB.
Problem is I cant see how to populate these extra fields in CME.  Can this be achieved by adding something to the annex tab?
Offline Haldane
Re: Populating COMMENT_ field in person object
« Reply #1 on: October 12, 2006, 12:47:50 PM »
The only way to add data to these fields is via the DB. The field "comment_" along with some other's are not used within any Genesys GUI's (That I'm aware off). They are just there for future ref.
Offline Genecist
    • Screen Pop Software
« Reply #2 on: October 12, 2006, 03:13:22 PM »
[quote author=Haldane link=topic=1861.msg6115#msg6115 date=1160657270]
And as such, is probably a bad idea to mess with it since it's not gauranteed to be there in a future edition of Genesys.
Offline Haldane
« Reply #3 on: October 13, 2006, 08:14:11 AM »
I think you'll be ok to use it as it's part of the config schema. I doubt they would remove it but you can throw in a service request to Genesys just to make sure.
