" /> Remove user-data - Genesys CTI User Forum
Author Topic: Remove user-data  (Read 2938 times)
JimH
Remove user-data
« on: October 12, 2006, 10:02:41 AM »
How do you delete user-data from a call using soft-phone or URS?
Offline Haldane
Re: Remove user-data
« Reply #1 on: October 12, 2006, 10:25:32 AM »
In the softphone you can use something like the following. (This is not compiled code )
Dim MykeyPair as CTKVPair
Dim MyUdata as CTKVList
Dim KeyPairCount as Integer
Dim i as integer
KeypairCount =MyUdata.GetCount
For i = 0 to KeyPairCount
// This will Delete all
Set MyKeyPair = MyUdata.Delete(i)
//This will delete particular
If MyKeyPair.Key = "The One to Delete" then
  MyUdata.Delete(i)
Next i
Marked as best answer by on July 25, 2025, 03:29:28 AM
perilman
« Reply #2 on: October 12, 2006, 12:25:46 PM »
  • Undo Best Answer
  • If you are using URS, you can issue Update['keyname',''] to delete it. It will not remove the key, but it will remove the value.
    I think there is a way to remove the key altogether, but I don't know how to do it it. Any suggestions?
