" /> Number of Licenses Used in TServer - Genesys CTI User Forum
Author Topic: Number of Licenses Used in TServer  (Read 3628 times)
Offline Haldane
« on: October 20, 2006, 02:35:23 PM »
Does anyone know of a call to Tserver to show num actual used SDN licenses.
jlennan
Re: Number of Licenses Used in TServer
« Reply #1 on: December 28, 2006, 08:47:36 PM »
[quote author=Haldane link=topic=1880.msg6196#msg6196 date=1161354923]
I don't know of a call, but if you open the t-server log and do a search for "licenses checked out"  it will say how many has checked out.
This number is equivalent to how many acd positions are programmed in the switch section of your CME, not by how many places are configured in CME.
If you check once, and don't add any more sdn licensed objects that number won't change.
tony
« Reply #2 on: January 05, 2007, 10:38:59 AM »
...if it's about how many Users and Logged In, you might consider the functionality provided by the LOGIN Table, for the StatServer.
Tony
