" /> GAD : QueueExecutor Timer WARN Ail.Queue - Genesys CTI User Forum
Author Topic: GAD : QueueExecutor Timer WARN Ail.Queue  (Read 2675 times)
Offline sitto
« on: November 15, 2006, 09:38:06 AM »
I found this log "QueuedExecutor Timer WARN Ail.Queue Executing task Object modified 4756 (29066176)" What does it mean?
This log makes a agent couldn't log in GAD with place 4756, when click submit the login page that doesn't go to next page and still be this page a long time.
Please help me, how to fix this log.
Peter K
Re: GAD : QueueExecutor Timer WARN Ail.Queue
« Reply #1 on: December 05, 2006, 12:25:24 PM »
Sitto - what version of GAD are you using?
In your logs, can you confirm that a request issued by GAD has been delivered by TServer to PBX and PBX has replied? We had a similar problem before with congested PBX link, forcing TServer to queue some messages. When this happened, Agent would be issuing the same request more than once, causing a similar message as the one you have described in your post.
So, check your TServer log for duplicate agent requests that would cause this and get to me with the result.
PK
