" /> full export of ODS DB and Geneysys configuration DB - Genesys CTI User Forum
Author Topic: full export of ODS DB and Geneysys configuration DB  (Read 3611 times)
MaxonMan
« on: March 01, 2007, 04:41:29 PM »
Hello ,
In order to fix a Service Request, the Genesys Support asked me to full export of ODS DB and Geneysys configuration DB export.
Do i have to use the Configuration Import Wizard for the two exports ?
thank you for your help.
Marked as best answer by on July 17, 2025, 01:28:42 PM
Re: full export of ODS DB and Geneysys configuration DB
« Reply #1 on: March 02, 2007, 02:53:28 AM »
  • Undo Best Answer
  • Well, I know there is a tool to export Genesys CME, but I did not know there was a tool for ODS. If you know how to use it, then by all means, go for it, but from my humble experience, a normal DB export would be just fine.
    Usually if I hve a CME DB-related proeblem, I send a CME DB export generated using a SQL Manager or Oracles export command.
    Best regards,
