" /> AttributeNetworkCallID - Genesys CTI User Forum
Author Topic: AttributeNetworkCallID  (Read 4158 times)
« on: June 11, 2007, 05:00:05 PM »
Hi guys,
I'm receiving this message constantly on the log incidents, does anyody has an idea of what is it? And from where it comes from? What is 65206? It is not an object on my Genesys.
Invalid TLib message received from 65206(--), wrong type of AttributeNetworkCallID
Re: AttributeNetworkCallID
« Reply #1 on: June 12, 2007, 06:32:46 AM »
Can you please show the log?
Usually NetworkCallID is issued by Avaya (or Alcatel) when you have more than one PBX and they are set up to swap calls. You should not get any errors with it though...
« Reply #2 on: June 14, 2007, 11:08:10 PM »
Using an Alcatel OXE PBX
17:45:02.748_T_I_0000000000000000 [14:0c] EventQueued is received for tserver TServerA4400[SwitchA4400] (this dn=64010)
    _C_W_00700173d5139585 [0D:03] default value (0) will be used for option use_parking_threshold
    _C_W_00700173d5139585 [0D:03] default value (3) will be used for option on_route_overlap
    _T_I_00700173d5139585 [01:11] connid 00700173d5139585 is bound to the call 115528-00d4e240
    _I_I_00700173d5139585 [01:01] call (115528-00d4e240) for Resources created
    _T_I_00700173d5139585 [14:09] add DN TServerA4400 64010 <64010@SwitchA4400> (CDN 57 00700173d5139585) to the call 115528-00d4e240 truly:22
received from 65205(--)genesys1:3100(fd=528) message EventRouteRequest
AttributeOtherDN '5161'
AttributeOtherDNRole 1
AttributeOtherTrunk 263813
AttributeThisDN '64010'
AttributeThisDNRole 2
AttributeThisTrunk 263813
AttributeThisQueue '64010'
AttributeCallState 0
AttributeCallType 1
AttributeCallID 16936
AttributeConnID 00700173d5139585
AttributeCallUUID 'C1E8A904-B6BC-47CA-A859-CF10DA07ADB1'
AttributeDNIS '64010'
AttributeCustomerID 'Resources'
AttributeNetworkCallID fcc5714628420100
AttributeExtensions [61] 00 02 02 00..
'GCTI_GLOB_CID' bin: FC C5 71 46.. (len=8)
'GCTI_SUPERVISED_TRANSFER' 0
AttributeTimeinSecs 1181861102 (17:45:02)
AttributeTimeinuSecs 748000
AttributeEventSequenceNumber 0000000000115fea
17:45:02.748 Std 04546 Invalid TLib message received from 65205(--), wrong type of AttributeNetworkCallID
pacohlopez
« Reply #3 on: June 27, 2007, 12:58:42 AM »
Hi Victor
I have the same kind of messages with an Alcatel 4400, and we are having some problems when we have high call volume, at that moment if we dial the RSI where the startegy is loaded we get a busy tone, and the only message I found is the one related with the wrong attributenetworkcallid, Do you think this error can cause a problem at the RSI?
12:28:44.685_T_I_0000000000000000 [14:0c] EventQueued is received for tserver TServerAlcatel(this dn=2063)
    _C_W_00d5016ca5082005 [0D:03] default value (0) will be used for option use_parking_threshold
    _C_W_00d5016ca5082005 [0D:03] default value (3) will be used for option on_route_overlap
    _T_I_00d5016ca5082005 [01:11] connid 00d5016ca5082005 is bound to the call 2-019846c0
    _I_I_00d5016ca5082005 [01:01] call (2-019846c0) for Resources created
    _T_I_00d5016ca5082005 [14:09] add DN TServerAlcatel 2063 <2063@AlcatelSwitch> (CDN 57 00d5016ca5082005) to the call 2-019846c0 truly
received from 65200(TServerAlcatel)CTI02:3000(fd=572) message EventRouteRequest
AttributeOtherDN '2792'
AttributeOtherTrunk 1276
AttributeThisDN '2063'
AttributeThisTrunk 264870
AttributeThisQueue '2063'
AttributeCallType 1
AttributeCallID 60928
AttributeConnID 00d5016ca5082005
attr_#141 'B477A218-F087-46A5-B309-8CBC0B617DB9'
AttributeDNIS '2063'
AttributeNetworkCallID 62b2d04500ee0900
AttributeExtensions [98] 00 03 02 00..
'GCTI_GLOB_CID' bin: 62 B2 D0 45.. (len=8)
'GCTI_NAT_INDICATIONTYPE' 'Public:Unknown'
'GCTI_NAT_INDICATION' '2792'
AttributeTimeinSecs 1171304924 (12:28:44)
AttributeTimeinuSecs 685000
attr_#148 0000000000000155
12:28:44.685 Std 04546 Invalid TLib message received from 65200(TServerAlcatel), wrong type of AttributeNetworkCallID
« Reply #4 on: July 05, 2007, 01:55:12 AM »
Hi, sorry for a belated reply.
I have asked around, but no one has seen this before. Invalid TLib attribute? Never have seen it?
What does Genesys say?
