" /> CCPulse and DMA - Genesys CTI User Forum
Author Topic: CCPulse and DMA  (Read 3607 times)
Offline Sylvainsjc
CCPulse and DMA
« on: June 13, 2007, 04:05:29 PM »
Hi all,
I use in CCpulse a template on which one stat is a formula like this :
((ccpulse.Total.statistic("Choix 1")
+ccpulse.Total.statistic("Choix 2")
+ccpulse.Total.statistic("Choix 3"))
/ccpulse.Total.statistic("Entrant SVI"))*100
Now i'm looking for to have this stat in historical datamart. I don't find any way with DMA.  Does anybody could help ?
Re: CCPulse and DMA
« Reply #1 on: June 13, 2007, 07:31:23 PM »
On DMA there is no way to do that, what you should do is to recreate the formula on BRIO or in CCPulse or whatever you are using to retrieve historical info.
Offline Sylvainsjc
Re: CCPulse and DMA
« Reply #2 on: June 14, 2007, 05:08:08 AM »
Thank you. It's on CCPulse that i wish to obtain this stat in historical. Do you know a way ?
Offline catanirex
Re: CCPulse and DMA
« Reply #3 on: June 14, 2007, 06:08:16 AM »
The formula you have will work if you associate the stats in the template  for both realtime stat and historical .
Associate it with the historical columns.
Offline Sylvainsjc
Re: CCPulse and DMA
« Reply #4 on: June 19, 2007, 10:16:41 PM »
Ok it works fine. I've created formulas in the template for QS and average call time and abandonned time.
