" /> Support for Cisco CallManager - Genesys CTI User Forum
Author Topic: Support for Cisco CallManager  (Read 4061 times)
Offline Leapfrog
« on: September 29, 2007, 09:15:42 PM »
Team,
What is the latest release of CallManager supported by Genesys v7.5 ?
Regards
Leapfrop
Re: Support for Cisco CallManager
« Reply #1 on: September 30, 2007, 03:04:02 PM »
The latest supported CallManager version is 5.1.1. You need TServer 7.5 in such case.
René
Offline Leapfrog
« Reply #2 on: October 01, 2007, 11:08:23 AM »
Thanks a lot René for your help.
I am challenged in internal of my company by telephony's department in charge to deploy CallManager. They ask me how I can be sure that Genesys and Cisco will run together. Because on the web site of Cisco, the current compatibility is between CallManager v4.1 and Genesys TServer 7.2.
Regards,
Leapfrog.
« Reply #3 on: October 01, 2007, 06:22:09 PM »
You're welcome.
Genesys is direct competitor of Cisco in the call centre area so I would doubt that certification takes some (long) time due "unknown" reason ;)
You can find supported versions of CCM in the release notes of TServer for Cisco CallManager.
René
andrew chau
« Reply #4 on: February 09, 2008, 03:21:15 AM »
Is the Genesys IP contact centre compatible to Cisco CallManager 5.1?
« Reply #5 on: February 09, 2008, 05:33:23 AM »
Genesys IP contact Center? What is that? Can you be more specific? Under Genesys all is IP so don't understand your question...
andrew chau
« Reply #6 on: February 10, 2008, 05:08:15 AM »
Sorry.... I would like to know the compatibility between Genesys Software ACD and Cisco CallManager 5.1.
Many tkx.
« Reply #7 on: February 10, 2008, 07:28:11 AM »
? Genesys is a CTI, one of his products is URS (Universal Routing Server) which is something like an ACD but much more advanced.
As Genesys is compatible with CCM and your version is covered I see no problems.
