" /> the length of the option value of filters - Genesys CTI User Forum
Author Topic: the length of the option value of filters  (Read 3227 times)
dink
« on: November 19, 2007, 02:41:28 PM »
When defining a filter in the options of the star server I have a problem with the length of the option value;
My filter has the following format
~pairexists (....) & ~pairexists (...) & ............
I am not able to enter the complete option value
I am a newbie in genesys; so maybe there is an easy solution. But now i am lost
Marked as best answer by on Yesterday at 07:24:52 AM
Offline Fra
Re: the length of the option value of filters
« Reply #1 on: November 19, 2007, 03:19:11 PM »
  • Undo Best Answer
  • Dink,
    as far as I know the value length was limited to 255 characters till 7.0 release; how long is yours?
    dink
    « Reply #2 on: November 19, 2007, 03:43:31 PM »
    that is the same limitation I have.
    Offline Tefleon
    « Reply #3 on: November 19, 2007, 06:07:30 PM »
    This is a guess but are you entering "~pairexists (....) & ~pairexists (...) & ............" as the value in the option box?
    dink
    « Reply #4 on: November 20, 2007, 01:18:54 PM »
    yes that's the way I have done it;
    I have a found a solution by using wildcard characters
