" /> Comments on ICON/Infomart Rough Guide...? - Genesys CTI User Forum
Author Topic: Comments on ICON/Infomart Rough Guide...?  (Read 5256 times)
tony
« on: February 14, 2008, 10:24:57 PM »
Too much? Too little? "OK"?
Tony
Re: Comments on ICON/Infomart Rough Guide...?
« Reply #1 on: February 15, 2008, 06:47:56 AM »
  • Hi Tony,
    It looks very interesting and well done, however, I have never used ICON nor CCON. So I can understand the idea, but can you please share a screenshot of what kind of reports we are talking about exactly? If it is not much to ask of course.
    tony
    « Reply #2 on: February 15, 2008, 01:44:25 PM »
  • Hmmm... small problem there... there is no reporting interface. Not yet, anyway...
    I take your point though - if I add in an Annex showing the types of statistics available (KVP's, Aggregate Stats, etc.) and applied to which objects (Agent, Queue, VQ, Campaign, etc.) - would that help?
    Tony
    ahmad
    « Reply #3 on: February 15, 2008, 03:02:29 PM »
  • Hi Guys
    I am having and issue when I can see that the persistent queue is getting updated but no data is updated in the database .
    I have check the dadabase connection seems to be ok.
    any other ideà.. welcome pls
    regards
    ahmad
    Offline eugene
    « Reply #4 on: February 15, 2008, 06:01:47 PM »
  • The document is very well written.  Keep'em coming Tony although I'm not sure which other products you haven't covered.  ;D
    « Reply #5 on: February 19, 2008, 04:19:55 PM »
  • [quote author=Tony Tillyer link=topic=2786.msg11180#msg11180 date=1203083065]
    Tony
    And what do you use to get the info? Seems it is not something a mortal user can do.
    The table views can help to see what we achieve with that :)
    tony
    « Reply #6 on: February 19, 2008, 10:51:05 PM »
  • Hi cavagnaro,
    Well... with a View applied, or a little script to pull in the data from the plethora of available Aggregated Tables you could push out the results to a new Table, apply a BOU over those, for use in a BO Report... BI work, basically.
    I don't have an integral Table or View Schema to show how the whole thing relates to itself but it doesn't appear to be too difficult to see how it works...
    BTW, I'm not pre-sales and I never said it was a good product - but it does extract very well (read: use ICON!) :)
    Tony
