" /> call can't be routed to agent - Genesys CTI User Forum
Author Topic: call can't be routed to agent  (Read 3015 times)
Offline sitto
« on: February 28, 2008, 02:27:29 AM »
Hi friends,
Have you found the same issue with me?
Calls can't be routed to agent and I found in StatServer log as below
Capacity snapshot for place '761150'('Resources'), agent '765049'('Resources') (CR='<system default>'
  media_state    current_number  max_number      routable
[ R                                  1              1                      0              ] <-- voice
Everytime when media_state is 'R' that means agent is ready but routable is '0' then call can't route to agent.
Do you know about this issue?
Many thanks,
TO
Re: call can't be routed to agent
« Reply #1 on: February 28, 2008, 03:24:12 AM »
Are you using capacity rules? How are they configured?
If not disable them on URS options.
