" /> Adding Another Dialogic Card in VTO - Genesys CTI User Forum
Author Topic: Adding Another Dialogic Card in VTO  (Read 2993 times)
Offline TTom
« on: February 29, 2008, 03:41:15 PM »
I'm going to add another dialogic card in a VTO server that has one already.  We are adding another dialogic card in the same server and I am wondering if there is any thing special that needs to be done?  I know I need to connect the two cards together by using a bus cable, and configure the porsts in CME but is there anything on the card we need to configure?
Offline bcyk
Re: Adding Another Dialogic Card in VTO
« Reply #1 on: March 03, 2008, 08:45:20 AM »
The easily way is to have both old and new boards are of the same TYPE.
- setting the "board ID" switch on the Dialogic card
  - the old board "should" be 0
  - the second board "should" be different than the old; e.g. "1"
- the Dialogic configuration manager should "see" the new Dialogic card after installation int the tree structure.
If the new board is different AND it is Digital lne-side card (T1 or E1), please make sure that drivers / protocol configuration are properly installed.
Setting in Genesys CME should be straight-forwards by referring to current configuration.
