" /> IVR recommendations Hicom & Genesys 5.1 - Genesys CTI User Forum
Author Topic: IVR recommendations Hicom & Genesys 5.1  (Read 5420 times)
Rick
Our initial IVR needs are VERY basic - just a few voice prompts and retrieving CED, but we want to be able to use more advanced IVR functionality in the future. We're also looking for a solution that will allow us to upgrade to Genesys 6.*. Easy installation and administration would be a plus. Any recommendations?
  • I think most of IVR would do fine. In each case, you would have to deal with a particular pecularity or two, but most of them are pretty much the same when it comes to implementation.
    Show'n'Tel , Periphonics seem to be leading in its integration with Genesys; however, pricewise it might be prohibitive...
    What are you considering at this point?
    Rick
  • We haven't started conversations with any vendors yet, but my initial research has narrowed the field to the list below. I have no prior experience with IVRs. We are looking to select a vendor by midJuly and implement by the end of September. We also want any solution to compatible with G6 when we are ready to upgrade. I appreciate your comments!
    1) Siemens voice prompt and CED w/Genesys 5.1 (no fulllown IVR)
    2) Genesys VTO w/Genesys 5.1
    3) Genesys VSS w/upgrade to G6
    4) Aspect/Voicetek Generations w/Genesys 5.1 (supported in G6)
    5) Brooktrout Show N Tel w/Genesys 5.1 (supported in G6)
    6) Edify w/Genesys 5.1 (supported in G6)
    7) IBM DirectTalk/6000 w/Genesys 5.1 (supported in G6)
    8) Lucent Conversant w/Genesys 5.1 (supported in G6)
    9) Nortel Symposium OPEN IVR w/Genesys 5.1 (supported in G6)
    10) Nortel Periphonics VPS/is w/Genesys 5.1 (supported in G6)
    Andrew
  • I'm investigating an IVR replacement for our existing Nortel Symposium Open IVR (we are using an Option 81C PBX Rel. 25), which is now supported and developed by Aspect. It is a good tool that has been reliable, but it is going to cost as much to replace it as it would to purchase a new system from a competitor Aspect's pricing is pretty outrageous compared to IntervoiceBrite, who is offering a very attractive displacement incentive.
    I have seen and heard very good things about IntervoiceBrite and their IVR platform, but have yet to confirm if it is G6 compliant.
    I have heard rumours that the Genesys VSS rollout has been delayed inevitably as they work out some major problems.
    We have an older Periphonics machine that is a major pain in the ass. Pretty reliable, but difficult to make quick prompt/callflow changes with. I don't know if Nortel has made any improvements to the platform since purchasing Periphonics. We are somewhat gun shy going with Nortel again we were reassured more than a few times that the Symposium Open IVR platform would be supported for years to come....two years later it was an abandoned product line.
    I have no idea how the above would integrate with a Siemens PBX.
    I have a two page Gartner Group report outlining the IVR industry and the major players. email me if you want it.
    hope this info helps
    Rick
  • Thanks, Andrew. I sent you an email about the Gartner IVR report.
    There is a document on the Genesys Support website called "Genesys 6.x Supported Switches & IVR". If you do a search in the Knowledgebase for it, you should find it. It has a table showing which IVRs are supported in G6. All of the ones in my list are supported.
  • Andrew,
    could you email it to me too? Thanks!
    As for IVR, Show'N'Tel and Intervoice would be my first and second choice, but then again, it is based on what I am playing with at the moment.
