" /> Avaya AES Link numbers and TServers - Genesys CTI User Forum
Author Topic: Avaya AES Link numbers and TServers  (Read 3556 times)
Offline sambo99
« on: March 18, 2008, 06:07:42 PM »
Hello, I am very new to Genesys and need to add a DLG link on my AES for a new Tserver. The next cti link number available on my AES is 9. Does anyone know if there is a link number limitation for Genesys like their is for ICM? ICM can only go as high as 8 due to a code restriction and I am trying not to get into an similar issue with my Genesys link if possible.
Thanks!
Ben Taylor
Re: Avaya AES Link numbers and TServers
« Reply #1 on: March 19, 2008, 11:33:57 AM »
doing the same thing today as it happens...
From the T-Server 7.5 for Avaya Communication Manager documentation:
link-number
Default Value: Mandatory field. No default value.
Valid Values: Any valid link number
Changes Take Effect: Immediately
Specifies the number of the ASAI Ethernet link dedicated for this use. You must set a value for this option.
Offline sambo99
« Reply #2 on: March 19, 2008, 12:13:53 PM »
Thanks Ben!
I appreciate your quick response.
