" /> CCPulse Terminology Question - Genesys CTI User Forum
Author Topic: CCPulse Terminology Question  (Read 4084 times)
Offline NCSC_User
« on: March 19, 2008, 05:13:23 PM »
I just got a question from one of my call centers asking:
Do you know what "On Hook" means in CCPULSE when looking at an agent in the extended veiw I am seeing that. I see others that do not have this. It stays there the whole time while she takes a call. While she is on Wrap time, while she is ready.
Any thoughts?
Re: CCPulse Terminology Question
« Reply #1 on: March 19, 2008, 05:58:55 PM »
Off Hook means you picked up the handset to be able to talk
On hook means the handset is "sleeping" on your phone.
Offline NCSC_User
« Reply #2 on: March 19, 2008, 06:01:32 PM »
How does that apply/translate in a GUI envirment?  We use a softphone system where you actually log in and open up all on ur screen instead of hardware.
« Reply #3 on: March 19, 2008, 06:20:52 PM »
no matter if software or hardware, in the call flow logic you still have to do something before talk, which is pick up the handset (hadrware) or request a line (software).
The event from the PBX is the same always.
tony
« Reply #4 on: March 19, 2008, 08:30:02 PM »
There's a bit of a difference between "states" and "types" when it comes to statistics.  "states" refer to attributes to the telecommunications device or line, whilst "types" refer to the actual interaction/call taking place on the telecommunications line...
For example: "offhook", "onhook" and  "AfterCallWork" (or "WrapUp") are states, whereas "CallInbound", "CallOutbound", "CallInternal" are types.
All of these "states" and "types" are reflected through the TServer as [i]Events[/i], all of which you can (with the right coding) extract and use in software which emulates handsets, etc.  So, even if you do not have a physical handset from which to create "offhook" and "onhook", the state change will be emulated through an [i]Event[/i] which is sent via a TServer, from/to the Switch/PBX.
These [i]Events[/i] can work both ways; if you want to emulate "offhook" a command can be sent via software running on the Desktop, connected to the TServer, to instruct the Switch/PBX to show the device as "offhook".  Similarly, if a call is answered through either hardware (a physical handset) or software (a softphone), the switch will confirm, via an Event to/through the TServer, that the device must be in an "offhook" state, before a call can be answered.
You probably didn't need all of that information, eh...? ;)
Tony
