" /> how can monitor speak using tsinglestepconf - Genesys CTI User Forum
Author Topic: how can monitor speak using tsinglestepconf  (Read 2908 times)
chairman
« on: April 06, 2008, 10:54:46 AM »
I use the API TSingleStepConference for adding the monitor to existing call. but i find the monitor only can listen the call instead of conference. how can make the monitor speak in this situation?
Re: how can monitor speak using tsinglestepconf
« Reply #1 on: April 06, 2008, 09:03:10 PM »
  • Hi,
    Usually it's possible to change type of participation by attaching predefined key in Extensions. You can find that information in TServer's manual.
    What switch do you have?
    René
