" /> PBX Simulator issue - Genesys CTI User Forum
Author Topic: PBX Simulator issue  (Read 2619 times)
Offline jsty40
PBX Simulator issue
« on: July 10, 2008, 11:51:43 AM »
Can't seem to queue a call for over 100 seconds.
All queued calls abandon after exactly 100seconds.
Tried solution on Genesys website of adding Annex Simulator Section with queue-tout set to 10 on switch object in CME..stop start..same thing..
anyone see this before ?  thanks
JS
Re: PBX Simulator issue
« Reply #1 on: July 14, 2008, 01:21:36 AM »
I do not know about CME options, but I use an option inside the batch file that calls n_simg3 to fix that:
-t 1000 -q 120
Try it and see if it helps :) Does the trick for me.
