" /> CCPulse 7.1 Silent install - Genesys CTI User Forum
Author Topic: CCPulse 7.1 Silent install  (Read 7093 times)
batemanldb
« on: August 01, 2008, 01:32:21 PM »
I am trying to do a slient install of CCPulse version 7.1.  The switches I have tried do not seem to work.  Any help would be greatly appreciated.
Marked as best answer by on Today at 11:56:11 PM
k
Re: CCPulse 7.1 Silent install
« Reply #1 on: August 01, 2008, 05:43:40 PM »
  • Undo Best Answer
  • What switches have you tried?
    You need the -r option to create the response file.
    You then play it back with switches -s /f1(setup file) /f2(log file)
    Try this: once you create the setup.iss file, move it to the same directory as the setup.exe, then try the install with only the -s option (taking the defaults on /f1 and /f2). If that works, then try adding the /f1 and /f2 option.
    If I recall correctly, I've encountered the following issues in the past with different versions of the CC Pulse silent install:
    1 - When specifying the path for /f1 and /f2, put quotes around it
    2 - there should not be a space between the /f1 (or /f2) switch and the first quote
    3 - if I did not specify only the file name, I had to specify the complete/absolute path for the file and could not specify relative paths
    4 - On one or two, the last section was missing from the file - I think it dealt with whether the platform was to reboot. Once I added that section, it worked.
    Please post the resulting .ISS file from your attempts, as well as the log file.
    « Reply #2 on: August 02, 2008, 08:33:22 AM »
    You can find "how to install CCPulse+ silently" in official documentation - Reporting 7.5 CCPulse+ Administrator's Guide.
