" /> logout an agent (by supervisor or after inactivity time) - Genesys CTI User Forum
Author Topic: logout an agent (by supervisor or after inactivity time)  (Read 5319 times)
Offline Doo-Bop
« on: October 28, 2008, 08:57:16 AM »
- logout an agent (by supervisor or after inactivity time). Most agents forgot to logout after shift.
is it possible?
Doo-Bop
Offline Doo-Bop
Re: logout an agent (by supervisor or after inactivity time)
« Reply #1 on: October 28, 2008, 09:24:56 AM »
it is genesys 7.2
« Reply #2 on: October 28, 2008, 02:26:44 PM »
1. create a software to do it
2. do it by hand at GAD admin
3. By PBX commands
Offline barleycorn
« Reply #3 on: October 28, 2008, 08:57:20 PM »
Fire them.... ;-)
Offline Dionysis
« Reply #4 on: October 28, 2008, 09:38:03 PM »
I concur... quite often there is a need to fire people when technical issues can't be solved.
However, you can easily use a cti application to register for the agent's place and send a request logout.  Any of Cav's solutions would do it.
« Reply #5 on: October 28, 2008, 09:43:29 PM »
lol, they will sue you as that is not a valid cause unless you specify in their contract such thing which is hard to do...
Offline Dionysis
« Reply #6 on: October 28, 2008, 09:58:11 PM »
Bah, that's not our area to worry about.  Let the legal dept worry about it.
:p
Offline barleycorn
« Reply #7 on: October 28, 2008, 10:16:01 PM »
;D
In all seriousness though, I've implemented this sort of thing a couple of times, and there's no real perfect solution to it.  I've done it through the softphone itself, through a management app (using AIL to present a right-click->log off style interface showing the agent and idle time), but really nothing beats training the agents that it's unacceptable to walk away from their workstation without logging off. Of course, there's always the odd mistake but if you find agents doing it continuously then it should be grounds for a caution at least.
