" /> Genesys Outbound Dialer - Genesys CTI User Forum
Author Topic: Genesys Outbound Dialer  (Read 5430 times)
ahdeshpande
« on: January 12, 2009, 05:51:36 AM »
What is the world's standard format for inputting telephone number in Genesys Outbound Dialer?
Marked as best answer by on Today at 09:27:29 AM
Re: Genesys Outbound Dialer
« Reply #1 on: January 12, 2009, 03:59:26 PM »
  • Undo Best Answer
  • ??? ??? ??? it will depend more on your PBX how it allows you to dial
    ahdeshpande
    « Reply #2 on: January 13, 2009, 03:53:13 AM »
    Hi Cavagnaro,
    Thanks. i am looking whether there is any World wide standard format used or recommended by genesys, which then can be filtered based on PBX?
    As i am new to Outbound, please do help me if you any documents, or useful information on the same.
    Regards
    Ashutosh H Deshpande
    « Reply #3 on: January 13, 2009, 06:30:16 AM »
    again, no standards, if you dial 0 and then your phone number is it ok, again depends on your PBX side and what limits you may face.
