" /> Outbound Dialer - Genesys CTI User Forum
Author Topic: Outbound Dialer  (Read 4490 times)
Offline vivek
Outbound Dialer
« on: January 26, 2009, 05:07:14 PM »
I am looking for Outbound dialer code written using VB or Java, please share with me if you have a sample code.
Thanks.
« Last Edit: January 26, 2009, 05:08:53 PM by vivek »
Offline Adam G.
  • Still Gorgeous.......
Re: Outbound Dialer
« Reply #1 on: January 27, 2009, 08:51:53 AM »
[quote author=vivek link=topic=3773.msg16178#msg16178 date=1232989634]
Thanks.
Errrrrrrr
For a softphone or to roll your own application to dial calls?
Pavel
Offline jbobinsk
Re: Outbound Dialer
« Reply #2 on: January 27, 2009, 11:41:10 AM »
Depending what you want, but still in such code the main role would play request TMakePredictiveCall with defined timeout.
Regards
jbobinsk
Offline vivek
Re: Outbound Dialer
« Reply #3 on: January 27, 2009, 04:44:31 PM »
Thanks for the replies....
I am building one using VB and Access DB. Lets see how it goes:)
« Last Edit: January 28, 2009, 03:21:07 PM by vivek »
Offline vivek
Re: Outbound Dialer
« Reply #4 on: February 05, 2009, 11:16:54 PM »
I've completed the coding and it works fine.
It is not like Genesys Outbound solution, but for my requirment it is ok.
Offline chandra
Re: Outbound Dialer
« Reply #5 on: February 06, 2009, 08:51:43 PM »
Hi vivek,
I am trying to write code for a outbound dialer. Can you share some ideas?
My email address is: chandu216@gmail.com
Chandra
Offline Acecare
Re: Outbound Dialer
« Reply #6 on: August 06, 2010, 05:18:09 AM »
VB can definitely handle the outbound dialer in coding. You made a good choice in your database which is accessible.
Hopefully, you already finished it and show us what have you done.
« Last Edit: August 07, 2010, 03:47:58 AM by Acecare »
