" /> t server ivr does not recognize gvp ports - Genesys CTI User Forum
Author Topic: t server ivr does not recognize gvp ports  (Read 10337 times)
Offline GenesysNewbie
« on: February 14, 2009, 06:01:17 PM »
avaya
vcs - gvp 7.5
dialogic
behind
Vcs is rejecting the call, but i do not know why.
escenario 1: When gvp is in a standalone mode it can answer teh calls....
escenario 2: when tserver ivr is Started it can not answer calls
i notice in tserver ivr logs a message:
dnis tlib does not exist ....
Offline CTIgem
Re: t server ivr does not recognize gvp ports
« Reply #1 on: February 17, 2009, 01:16:54 PM »
DNIS triggers your IVR application.
Seems like you didn't associate DNIS numbers in your IVR configuration.
I haven't gone to 7.5 yet so don't know the details on how...
« Reply #2 on: February 26, 2009, 04:56:28 AM »
hi, in fact
i cannotice that is  a URL IVR issue, let em explain better.
when i configure it in this way http:localhost:9810/....$did$.xml <== gvp can not answer;
but when configured like this http:localhost:9810/....78967.xml  l<== gvp can  answer calls perfectly;
GVP 7.5.003,
-does anybody know if a hot fix exists 4 this problem?
-what happens if i let the configuration like this  http:localhost:9810/....78967.xml , this could generate problems?
Offline Earil
« Reply #3 on: February 27, 2009, 12:28:36 PM »
Because you are in a Behind-the-Switch mode, the URL must be : http://localhost:9810/did_url_mappings/GenericDID.xml.
For more explanation, go to page 443 of the document "Genesys Voice Platform 7.5 Deployment Guide".
Hope it helps.
« Reply #4 on: March 09, 2009, 04:35:40 PM »
ok it works,  but the problem now is that ANi is not coorect. With 79197.xml it works...
The GenericDID.xml works together with teh same values for $did$.xml or i shoul look other values for CFA or Popgateway url´s .......
Offline CTIgem
« Reply #5 on: March 10, 2009, 06:16:51 PM »
In CFA setup
Use CTI Client For ANI & DN set to 1?
Offline chandra
« Reply #6 on: March 10, 2009, 08:00:54 PM »
Try regenerating the IVR profile..This might solve the problem if $did$ is rejected....
---Chandra
« Reply #7 on: March 10, 2009, 09:48:24 PM »
yes CTIGen. cti client is set to 1; chandra  i regenerated the ivr profile with no positive results.
GVP with CTI integration is answering, the problem is the GEnereicDID.xml...when i set this value gvp stops showing the right ANI.
This issue is very particular, if i replace GenericDid.xml with 76544.xml (CDN) Gvp answers and shows teh correct ani!!!, but is not posible to set gvp in this way.
Popgateway - full log level does not show any error .....
(By the way TechSupp is getting worst every day , i am waiting for help by 2 days)
Offline CTIgem
« Reply #8 on: March 11, 2009, 11:38:10 AM »
Then your ANI/DNIS comes from Tserver, is your Tserver showing the wrong value?
« Reply #9 on: March 11, 2009, 03:10:10 PM »
yes CTIGen, gvp get the ani from iverserver, but in logs i can notice tserver is passing the wrong ani.
10:17:44.038 Trc 04541 Message EventRinging received from 65200 ( 'TServer_G3_72')
@10:17:44.0380 [0] message EventRinging
    AttributeDNIS    '6154328'  <==  DID
    AttributeANI    '16290000'  <=== this is the wrong ani showed when  GenericDID.Xml is set.
Based in your experience what should i revise to debud thsi issue.
« Reply #10 on: March 11, 2009, 04:37:49 PM »
Information provided by TServer in the events come from Avaya switch. Ask you Avaya admin to check that ANI isn't changed during routing of the call. Sometimes it's could be a bit tricky to configure the switch properly...
« Reply #11 on: March 11, 2009, 06:44:09 PM »
Thank u very much Rene,a really apreciate ur help.
I will  ask her about it.
« Reply #12 on: March 21, 2009, 01:42:00 AM »
hi rene i validate with the switch adminsitrator that ani is arriving ok.
78697 = CDN
i really dont understand what is happening.... in my understanding this string http:l.....xml. is relationed only with the dnis not with teh ani.
But when when i force teh string this way (http:...78967.xml) ani appears ok.
with GEnericDID.xml ani is showed an incorrect value.
clues? ideas? what i can look 4?
« Reply #13 on: March 24, 2009, 01:25:41 PM »
Could you please collect logs of TServer, IVR TServer and VCS (PopGateway1) logs and post these here. I will look at it then.
PS. All logs have to be debug level.
« Reply #14 on: March 24, 2009, 11:36:44 PM »
hi rene i can resolve the problem. thank u very much!
