" /> Searching based on LoginID? - Genesys CTI User Forum
Author Topic: Searching based on LoginID?  (Read 2927 times)
Offline Vincent
« on: April 27, 2009, 12:26:42 PM »
I know that Genesys is using an internal LoginID for agents, which you can see in CME with correct conifguration. However i want to search on these LoginIDs. I'm seeing some errors in SCI and want to know for which agents this is happening. Anybody got any ideas?
Offline catanirex
Re: Searching based on LoginID?
« Reply #1 on: April 27, 2009, 12:35:26 PM »
Select Tools - Find in CME
Select Agent Login - add the number you see in SCI
Double click on the result, and select Dependency tab. There you see the agent which the login id belongs to
Hope this helps!
Offline Vincent
« Reply #2 on: April 27, 2009, 12:55:13 PM »
Thanks, i'll check that out.
