" /> problem with LICENSE MANAGER - Genesys CTI User Forum
Author Topic: problem with LICENSE MANAGER  (Read 4322 times)
chauvat
Hello, I have a problem with LICENSE MANAGER it gives me the following message:
8:46:58 (genesys.d) Wrong hostid, exiting (expected SENTINEL_KEY=b285f2e9, got SENTINEL_KEY=0).
8:47:13 (lmgrd) Please correct problem and restart daemons
Which is the problem?
H.Matsumoto
  • You are sure you have the right sentinel key attached and have the correct license file? It sure sounds like you either do not have the right sentinel key, have the wrong license file, or your sentinel key is not properly installed.
    H.Matsumoto
    chauvat
  • Unfortunately, that functioned until the last stopping of the machine. Therefore I think that it is the dongle which died!
    Frederic CHAUVAT
    Victor
  • I am pretty sure it is the sentinel key that died. We had the same problem. Just exchange it and everything will be fine, I think.
