" /> Genesys SIP endpoint - Genesys CTI User Forum
Author Topic: Genesys SIP endpoint  (Read 4074 times)
Offline Boy
« on: July 10, 2009, 06:31:42 AM »
I am looking, for solution, based on Genesys, for small (<30) agents CC. My idea is to use Genesys SIP server and GAD with Genesys SIP endpoint.  Does anybody have experience with GAD & SIP endpoint? Is it good enough?
Thanks.
Offline peters
Re: Genesys SIP endpoint
« Reply #1 on: July 10, 2009, 09:12:06 AM »
we are using it for customer with 15 agents and with external usb soundcard. You have to meet some criteria (disabled popups on IE, no/configured firewall,editing of hosts file). The most problems that we have to solve here are dealing with windows/updates/popups blocker, sometimes sound goes to sound card and not to external usb sound card and so on. Often we have to connect remotely to agent's pc and check if phone is registered.
If i had the option, i would recommend hardphone, ie aaastra 53/55i. To fully use aastra, use sipserver 8, otherwise 2-step transfer will not work.
Peter
Offline Boy
« Reply #2 on: July 10, 2009, 10:30:00 AM »
Peter, why did you use external usb soundcard?
Ranjit Patel
« Reply #3 on: July 10, 2009, 07:43:02 PM »
We are using
Genesys SIP Server.
GAD
CounterPath Bria -- SIP End Point
Offline xember
« Reply #4 on: September 01, 2009, 09:11:48 AM »
Guys how did you manage to get rid of the fact when calling from the desktop an other extension the phone of the calling party starts to ring? I know it should be an option on the annex tap of the extension DN but for some reason I can not find out how.. any help is welcome on this..
Kind Regards,
Peter
« Reply #5 on: September 01, 2009, 02:56:53 PM »
What do you mean? The ringback? It is normal, otherwise how does the calling person will know that the call is ringing on the other side and is not a failed call?
