" /> TRouteCall is only for genesys internal use - Genesys CTI User Forum
Author Topic: TRouteCall is only for genesys internal use  (Read 3518 times)
Zaman
« on: July 13, 2009, 03:50:20 PM »
I need to use TRouteCall in my application to route call to specified agent. But documentation saya that this function is only for Genesys internal use. Do i need to get some type of license to embed this functionality in my application.
I am using tlib 7.2.
Genesys platform SDK also says that this functionality is for Genesys internal use.
Any comments please.
Regards,
Zaman
Offline bcyk
Re: TRouteCall is only for genesys internal use
« Reply #1 on: July 13, 2009, 04:08:27 PM »
Started from 7.0, some CTI-link functions (e.g., TRouteCall) and Genesys functions (e.g., TRegisterAll/TUnregisterAll) were removed from SDK/tlib library.
There is an 'alternative' if you have previous tlib versions, say version 6.x or 5.x.
Header files in 6.x/5.x contain TRouteCall() and other "for internal use only" function declaration.
In link option, both 7.2 and 6.x/5.x tlib library files should be included.
It is not sure if special license is available for "internal use" functions; please consult your Genesys sales.
Marked as best answer by on Today at 05:45:51 AM
Zaman
« Reply #2 on: July 13, 2009, 04:18:02 PM »
  • Undo Best Answer
  • Did Genesys provided the same functionality in any other shape?
    Any other function or way in tlib 7.2 or Genesys Platform SDK to achieve tha same functionality?
    Regards,
    Zaman
    Offline kowari
    « Reply #3 on: July 15, 2009, 05:54:43 AM »
    Not that I am aware of.
    It is probably in there so that URS can use it (there is a TRouteCall in that) but wasn't meant for softphones.  I am guessing that is what "internal use" meant.
    If you want to throw a call somewhere from a softphone use the transfer functions or conference functions.  You can look those up in the SDK easily enough.
