" /> ? in CCP - Genesys CTI User Forum
Author Topic: ? in CCP  (Read 3594 times)
Victor
? in CCP
does anyone know the reason for a [?] next to the agent status? I know this happens if you do not define the place for that person, but in this case place was defined. What makes problem even more interesting, if you click on the agent, his current status and statistics will be shown in the right window (CCP 5.1.070)
Anyway to fix that problem?
Oscar Jaen
? in CCP
  • I had a problem similar sometime ago, well, i killed statserver
    and started again and the problem was solved
