" /> Hiding private/sensitive data in GVP 7.6 logs? - Genesys CTI User Forum
Author Topic: Hiding private/sensitive data in GVP 7.6 logs?  (Read 5456 times)
Rod
« on: August 04, 2009, 04:46:29 PM »
As the subject field says really.
The deployment I'm working on handles sensitive customer information and the client wants it hidden.
How can I do it if at all?
TIA,
Rod.
Offline Infinity
Re: Hiding private/sensitive data in GVP 7.6 logs?
« Reply #1 on: August 04, 2009, 06:01:25 PM »
Can you be a little specific about which logs you are talking about here please?
tony
« Reply #2 on: August 05, 2009, 02:00:48 PM »
Apparently, with 8.1 you can... don't think it works in 7.6, though...
[i]"Enhanced Security features—GVP components now support the masking of sensitive data."[/i]
Tony
Offline Steve
« Reply #3 on: August 05, 2009, 02:41:10 PM »
In some apps (7.6+) you can use the [i][b]log-filter[/b][/i] and [i][b]log-filter-data[/b][/i] sections in the options tab of the app in CME, I'm not sure if these work in GVP or not.
But basically log-filter sets the standard behavior for KVPs in the logs and log-filter-data overrides this for specific KVPs. So you could set the option [i][b]default-filter-type[/b][/i] in log-filter to "copy", this would allow all KVPs to be copied into the logs and then hide individual KVPs in the log-filter-data section i.e. V_SURNAME=hide
The available options are -
copy - The keys and values of the KVPs are copied to the log.
hide - The keys of the KVPs are copied to the log; the values are replaced with strings of asterisks.
skip - The KVPs are not copied to the log. NOTE – Using this for the default-filter-type will block all userdata etc from the logs.
tony
« Reply #4 on: August 05, 2009, 03:04:51 PM »
Steve - I looked that up beforehand and found that, as you might expect, GVP has a totally different build to the core/Framework components, hence the log file masking techniques do not work on any GVP 7.6 components...
HTH?
Tony
Offline Steve
« Reply #5 on: August 05, 2009, 04:44:54 PM »
Aah, typical !
Roddy Black
« Reply #6 on: August 11, 2009, 09:22:23 AM »
That's what I thought.
Have been thinking it may just be a case of reducung the logging level on GVP.
Marked as best answer by on July 24, 2025, 06:03:29 AM
tony
« Reply #7 on: August 11, 2009, 03:01:06 PM »
  • Undo Best Answer
  • I think that, even if you did, the attached data items (KVP) [i]may [/i] still appear - and they will not be masked...
    You could always try it out..?
    T
